TwinTurbo.NET: Nissan 300ZX forum - When is the rattle occuring? Only at idle? At higher rpms?>>
Subject When is the rattle occuring? Only at idle? At higher rpms?>>
Posted by ZUL8TR on January 16, 2011 at 7:11 AM
  This message has been viewed 70 times.
In Reply To Wierd noise coming from rear passenger side of engine near. posted by blkrocket on January 15, 2011 at 12:59 AM
Message Better describe rattle sound?
Is idle erratic?
Describe the poor performance you are having?
Have you checked for codes?
Look into MAS connector and mas sensor.
Look into coolant temp sensor connector and sensor spec.
Is your POP Charger free of leaks at connections?
Consider a compression and leak down test.
Have you done the timing belt service?
ZUL8TR in Orlando,FL
